Martin Posted July 23, 2017 Share Posted July 23, 2017 Hi, didn´t want to use the Guide to cv thread. The Volvo 340 lobro has appr 0,75mm lateral clearance on the Rover driveshaft. Do I need to shim that somehow? Cheers Martin did want to contact you directly Nick but my private and business mail has problems Link to comment Share on other sites More sharing options...
Nick Jones Posted July 23, 2017 Share Posted July 23, 2017 Hi Martin, Yes, I shim it and also use spline locking compound on final assembly. I have some shims here but the thickness is not ideal as usually 1 is not enough and 2 is too much...... Happy to send you some if you want? Nick Link to comment Share on other sites More sharing options...
Martin Posted July 24, 2017 Author Share Posted July 24, 2017 Hi Nick, are these shims special ones for driveshafts (with a spline pattern?) or "normal" round ones? For nomal ones I always "visit" the storage of a mate with a machine shop. Martin Link to comment Share on other sites More sharing options...
Nick Jones Posted July 24, 2017 Share Posted July 24, 2017 Just normal round ones. Nick Link to comment Share on other sites More sharing options...
Martin Posted July 24, 2017 Author Share Posted July 24, 2017 shims sourced with a short visit at the mate´s workshop. However, the snap ring seems to be weakened. I measure 1,6mm Diameter with an outer Diameter of 24,5mm. The grove is 2mm wide. Can you confirm this data? Martin Link to comment Share on other sites More sharing options...
Nick Jones Posted July 24, 2017 Share Posted July 24, 2017 Not critical provided it all fits together snugly. I usually re-use the ones from the Rover shaft which have "ears" for circlip pliers. Clips are usually narrower that the groove - 1.6 - 1.8mm maybe, which needs to be considered when choosing the shims. Don't have any on hand to measure. Nick Link to comment Share on other sites More sharing options...
