Hurricane1500 Posted May 30, 2015 Share Posted May 30, 2015 So with the new Zetec engine I get 10 degrees advance built in that the megajolt does not pick up How do I correct that out for the map? Link to comment Share on other sites More sharing options...
Nick Jones Posted May 30, 2015 Share Posted May 30, 2015 ?? Do you mean that the trigger wheel has a mechanical 10º advance built in?? Not sure about MJ but most versions of MS allow you to enter an offset or correction factor that applies to the whole map - would expect MJ to be the same? Nick Link to comment Share on other sites More sharing options...
