SteveA Posted August 15, 2014 Share Posted August 15, 2014 So in the GT6 accident last year the electronic tacho, from a Triumph 2500s, died and I havn't been able to find another donor six cylinder tacho since. I have heard mention that you can re-calibrate a four cylinder tacho to six cylinder, does anyone have any pointers on how to do this? My thinking was that it would be much easier to get a donor tacho from a later Spitfire or Dolomite and convert that for my needs. Link to comment Share on other sites More sharing options...
PeteClan Posted August 15, 2014 Share Posted August 15, 2014 What's the damage to the original? Could be worth contacting Speed Cables as I've used them in the past to both repair and re-calibrate electronic tachos. Pete Richards Link to comment Share on other sites More sharing options...
SteveA Posted August 15, 2014 Author Share Posted August 15, 2014 There is probably a fault somewhere on the circuit board becasue as soon as supply power is put on to it, the needle stikes over to maximum and stays there. I tried changing circuit boards with the other tacho I had, but the fault follows the circuit board. The second tacho is slow to respond and does not show a true reading, even at a steady speed. Link to comment Share on other sites More sharing options...
CHRIS211083 Posted August 15, 2014 Share Posted August 15, 2014 Call chic doig sports cars. He will also know how or if you can convert them over. Chris. Link to comment Share on other sites More sharing options...
GT6 Nick Posted August 15, 2014 Share Posted August 15, 2014 Both my Herald and GT6 have converted tachometers. A gauge shop here in Oz uses the internals from an aftermarket tachometer, with the Smiths' gauge face and needle. The scales are similar, but not perfect - comparing my Herald's converted tach to an unmolested electronic one showed that the new one reads 6000rpm when the engine's actually doing about 5700. I figure that's close enough. N Link to comment Share on other sites More sharing options...
Nick Jones Posted August 15, 2014 Share Posted August 15, 2014 Steve, I found my extra one recently (amazing what turns up when you you are clearing up ready to move!). It's the later 2500S one, voltage sensing. Nick Link to comment Share on other sites More sharing options...
