bestquality03 Posted September 20, 2012 Share Posted September 20, 2012 After installing EFI in my GT6 last year I have been unhappy with the fuel pump setup so I made this (with a little help from some friends) Link to comment Share on other sites More sharing options...
GT6MK3 Posted September 20, 2012 Share Posted September 20, 2012 Awesome Tim. If I was in England I'd be ringing you to ask if I could order one. I do work at a fabricators here in Oz that have laser cutting, bending and TIG facilities though. Would you be willing to send me a copy of the CAD file so I could have my local fab shop make a one off(for a reasonable licence fee of course.)? Craig Link to comment Share on other sites More sharing options...
Nick Jones Posted September 21, 2012 Share Posted September 21, 2012 Nice work Tim. Presumably it just works as intended - no drama. Craig - you might find you need to make two - suspect Mr Moore might like one of those........ Nick Link to comment Share on other sites More sharing options...
GT6 Nick Posted September 21, 2012 Share Posted September 21, 2012 Mr Moore had a similar idea, but fitted an in-tank EFI pump and swirl pot into his existing tank. It is a good idea though, and if I hadn't already finished mine, I'd be keen. I spent last night wiring up the pump, running a feed and earthed return from the tank to the relay board under the dash. The relay's controlled by the Microsquirt. So that's about 1% of the electrickery done :-) Link to comment Share on other sites More sharing options...
bestquality03 Posted September 21, 2012 Author Share Posted September 21, 2012 Hi Craig I will willingly send you the autocad files but it is quite specific to my individual requirements and yours may be different. The CAD file isn't entirely complete either as we did need to make some bits to suit. The drawing I have is enough to get you going thou. Link to comment Share on other sites More sharing options...
bestquality03 Posted September 21, 2012 Author Share Posted September 21, 2012 Nice work Tim. Presumably it just works as intended - no drama. Craig - you might find you need to make two - suspect Mr Moore might like one of those........ Nick Hi Nick fits like it grew there!! With the boot boards and carpet in place and half a tank of fuel the pump is significantly quieter than any other install i have had previously. I do have a slight issue in melting the fuel pump fuse but this started before we made the tank so it's an underlying issue I haven't sorted yet. My co-driver for the RBRR is an ex-RAF electronics engineer so he is popping round on sunday to give it the once over to try and find the problem. Link to comment Share on other sites More sharing options...
AndyGT6 Posted September 21, 2012 Share Posted September 21, 2012 It certainly looks like it belongs in there . Andy Link to comment Share on other sites More sharing options...
GT6MK3 Posted September 21, 2012 Share Posted September 21, 2012 Hi Craig I will willingly send you the autocad files but it is quite specific to my individual requirements and yours may be different. The CAD file isn't entirely complete either as we did need to make some bits to suit. The drawing I have is enough to get you going thou. Tim, That would be really appreciated. My email is craig at craigtrimble.com Thanks Craig Link to comment Share on other sites More sharing options...
bestquality03 Posted September 22, 2012 Author Share Posted September 22, 2012 Tim, That would be really appreciated. My email is craig at craigtrimble.com Thanks Craig Hi Craig I will send it Monday Link to comment Share on other sites More sharing options...
