spitfiredred Posted December 25, 2011 Share Posted December 25, 2011 Hi guys Just relised (DDuuuHHH) after buying hood and frame for my mk2 spitty i aint got any brackets on posts to slot the frame into. the brackets to bolt my hardtop down are there but thats it. below the bolt brackets for the hardtop theres holes in the post which i assume are for the frame brackets. Question is what am i looking for. they where not there when i started on it lol. all the books ive got on mk2 spitfires dont show the brackets. any help on this matter would be appreciated. Link to comment Share on other sites More sharing options...
mattius Posted December 31, 2011 Share Posted December 31, 2011 i made some brackets to fit a mk2 hood to my 1500 they may help you Link to comment Share on other sites More sharing options...
Hurricane1500 Posted December 31, 2011 Share Posted December 31, 2011 I have a mark III you could use if you want a better set up PM if your interested Link to comment Share on other sites More sharing options...
Oli Posted January 2, 2012 Share Posted January 2, 2012 The new tub for my mk3 spitfire is a mk2 shell so I'll have a look whether i can take the brackets off in one piece if you want? They've got to come off anyway as I've got a mk3 hood frame which i'm planning to fit - this may take me a few weeks to get round to doing though Oli Link to comment Share on other sites More sharing options...
spitfiredred Posted January 6, 2012 Author Share Posted January 6, 2012 cheers Oli if u can take a few pics as well so i can see angles would be great. and if u can get em off in one go just give me a price cheers Eddy Link to comment Share on other sites More sharing options...
Escadrille Ecosse Posted April 25, 2020 Share Posted April 25, 2020 Folks, resurrecting this thread as I am in a similar position in that the mounting brackets for my car were removed as part of the original race car preparation as the car was run with a super lightweight glassfibre hard top. With the car going back on the road I'm putting the soft top back on but the brackets are now long lost and it's not clear exactly where they went on the B posts. I've got a bit of tube that's a good fit for the frame but can anyone provide photos and dimensions of the brackets and exactly where they fit so I can fabricate something. Thanks in advance Link to comment Share on other sites More sharing options...
Nick Jones Posted April 25, 2020 Share Posted April 25, 2020 There's been a more recent thread on this somewhere..... within last couple of years, though myabe not this forum. Seem to remember that there or two versions of the Mk2 frame (or is it the mk3?) Link to comment Share on other sites More sharing options...
Escadrille Ecosse Posted April 25, 2020 Share Posted April 25, 2020 Hi Nick The Mk1 and Mk2 frames are the same, it's the Mk3 that has two different versions. The early ones have over centre catches to attach to the windscreen header like the Vitesse. Late ones have the levers like the Mk4/1500. I had a hunt and you are right there was a more recent thread about Mk1/2 frames but it was asking if there were differences between the two models unfortunately. Also found some chat on the US forums but again nothing on the actual bracket detail. I did find someone listing a pair of the proper Mk1/2 brackets for the hardtop. Buy it now for £275 (plus postage of course) so I'll not be bothering with those. https://www.ebay.co.uk/itm/Triumph-Spitfire-Mk1-2-Hardtop-Brackets/114167839535?hash=item1a94eefb2f:g:v48AAOSwk~pehicT Link to comment Share on other sites More sharing options...
triumphlux Posted April 25, 2020 Share Posted April 25, 2020 Hi, I found this picture when I restored my Mk1 : The top of the tube is 42 cm above the inner sill. Hope this helps JC Link to comment Share on other sites More sharing options...
Escadrille Ecosse Posted April 25, 2020 Share Posted April 25, 2020 Hi JC. That's great. Thanks very much. I should be able work out things from there Cheers Link to comment Share on other sites More sharing options...
triumphlux Posted April 26, 2020 Share Posted April 26, 2020 Link to comment Share on other sites More sharing options...
Escadrille Ecosse Posted April 29, 2020 Share Posted April 29, 2020 So after looking at Triumphlux's photo and various other pictures on the net it clear that the mountings are not really tubes as such but two sheet metal pressings, one inside the other forming the mounting. Difficult to describe really. But probably not quite as difficult as making them in the garage with very basic metal working tools. Made from 20g (1mm) steel strip. The outer bit was not too bad, the inner bit was a right 'mare. Attempt number three on the bench there. One down, one to go. I'll spot weld the two pieces together and weld in a washer to form the bottom before trimming the flanges and MIG welding into the car and painting everything. Link to comment Share on other sites More sharing options...
Nick Jones Posted April 29, 2020 Share Posted April 29, 2020 Inner bit does look tricky. Certainly getting it to finish with the right relative dimensions is a challenge. Would it be easier to make the inner bit first and then make the outer to match it? Seems to have come out nicely in the end. Now to make another..... Link to comment Share on other sites More sharing options...
Escadrille Ecosse Posted April 29, 2020 Share Posted April 29, 2020 Hi Nick. I did start off that way but then realised that the key dimension is the hood frame itself which is 5/8" (16mm) and it's easier to make the outer to fit the frame then try and make the inner to fit the outer. Trick I found was to make the inner as a plain 'top hat' section slightly wider the inside of the outer section. Then clamp it down on a bit of steel plate and support the sides with some channel. With everything held down a few solid thumps with a blunt bolster chisel forms the groove. Bit of a faff getting it in and out of the clamps to check the fit but it worked OK in the end. Now as you say. Lets make another... Link to comment Share on other sites More sharing options...
triumphlux Posted April 29, 2020 Share Posted April 29, 2020 Wow, that really looks like the original Did you check with the hood frame on the car that the final distances work out fine? Better do that now before you fabricate the second one JC Link to comment Share on other sites More sharing options...
Escadrille Ecosse Posted April 29, 2020 Share Posted April 29, 2020 Thanks JC Oh yes, there was much measuring before I started Link to comment Share on other sites More sharing options...
Escadrille Ecosse Posted May 4, 2020 Share Posted May 4, 2020 After much, much more measuring. Brackets finally fitted and painted Link to comment Share on other sites More sharing options...
John I Posted May 4, 2020 Share Posted May 4, 2020 Nice looking job. Link to comment Share on other sites More sharing options...
Escadrille Ecosse Posted May 4, 2020 Share Posted May 4, 2020 Thank you. Although it now occurs to me that getting my bespoke rear roll cage back in round the new brackets may be slightly problematic. We shall see... Link to comment Share on other sites More sharing options...
Nick Jones Posted May 4, 2020 Share Posted May 4, 2020 Looks factory. Nice work. Link to comment Share on other sites More sharing options...
TimBancroft Posted May 10, 2020 Share Posted May 10, 2020 EE, Have you got a mk2 frame, if not I have one in my shed? Was given to me, so no money needed...of course transport etc my be difficult...Where are you. I am in Hampshire, near Basingstoke. Link to comment Share on other sites More sharing options...
Escadrille Ecosse Posted May 10, 2020 Share Posted May 10, 2020 Tim Thank you very much for the kind offer. I am in Glasgow, so a wee bit away unfortunately I actually have a frame which seems to be in decent nick and just needs painting so hopefully all fine. But thank you Link to comment Share on other sites More sharing options...
