DaveNotSoSideways Posted February 12, 2008 Share Posted February 12, 2008 Not sure where I found this, but its GOOD fun!!! http://members.iinet.net.au/~pontipak/redsquare.html My best after 10 goes is 33seconds. I think that is quite good. Beat me, I will be checking all claims out with my special photoshop fraud device )) Link to comment Share on other sites More sharing options...
Jony Posted February 13, 2008 Share Posted February 13, 2008 u wud post these things when ur hyped up on coffee and were all knackard:P 27 best after a couple of oes but makes me even tireder! Link to comment Share on other sites More sharing options...
AJ.Lintern Posted February 13, 2008 Share Posted February 13, 2008 I think it's down to luck once you get above about 16 - probably why I can't get much beyond that Link to comment Share on other sites More sharing options...
DaveNotSoSideways Posted February 13, 2008 Author Share Posted February 13, 2008 If the blocks changed or were randomised each time, it would be true test...I just learnt where to go and sit quietly and not move, then move to another spot, do the same and repeated what worked and memorised the pattern....Do admit over 22-25 seconds its rather HARD! Link to comment Share on other sites More sharing options...
DaveNotSoSideways Posted February 13, 2008 Author Share Posted February 13, 2008 Sorry Jony5? Link to comment Share on other sites More sharing options...
Jony Posted February 13, 2008 Share Posted February 13, 2008 it only took a few hours for you to get that far:P its when it gets about 22 secs it goes mad so you have to be quick moving, but your right its just learning where to go Link to comment Share on other sites More sharing options...
wfarnworth Posted February 13, 2008 Share Posted February 13, 2008 Yep, Hiding in quiet spots is the key Wayne Link to comment Share on other sites More sharing options...
elsieolly Posted February 13, 2008 Share Posted February 13, 2008 Yep looked at it a while and there is defintatly a couple of spots to hide in top left being best Link to comment Share on other sites More sharing options...
willcolumbine Posted February 13, 2008 Share Posted February 13, 2008 If the blocks changed or were randomised each time, it would be true test...I just learnt where to go and sit quietly and not move, then move to another spot, do the same and repeated what worked and memorised the pattern....Do admit over 22-25 seconds its rather HARD! Dave - I think your comment here illustrates the point of these tests nicely! Most pilot tests are about complex pattern spotting rather than having quick reactions. Its much more useful as a pilot to be able to patern spot and do multiple tasks simultaneously rather than just being quick. The industry standard PILAPT test is a real challenge! Basically you need to keep a 2 bars over a point on the screen with a joystick (with one axis reversed!) while being read patterns of numbers. When the gap between the numbers changes you need to press a button. Every so often the voiceover says something like 'red triangle' and you have to press the red colour key when the specified shape appears in the corner of the screen. That really sorts the men from the boys! Link to comment Share on other sites More sharing options...
DaveNotSoSideways Posted February 13, 2008 Author Share Posted February 13, 2008 (sleep)(sorcerer) Link to comment Share on other sites More sharing options...
DaveNotSoSideways Posted February 13, 2008 Author Share Posted February 13, 2008 I agree Will. I am glad you boys are being well trained! That sounds proper hard! Do you get to practice much first? Link to comment Share on other sites More sharing options...
wfarnworth Posted February 13, 2008 Share Posted February 13, 2008 Can I have my gold star and PhotoShop Guru status now please? 8) Wayne Link to comment Share on other sites More sharing options...
PHOENIX Posted February 13, 2008 Share Posted February 13, 2008 useless with toucpad on laptops. ??) Link to comment Share on other sites More sharing options...
wfarnworth Posted February 13, 2008 Share Posted February 13, 2008 Oh, and some tea bags and a pack of Peak Freens Trotsky Assortment while you're at it. Wayne Link to comment Share on other sites More sharing options...
DaveNotSoSideways Posted February 13, 2008 Author Share Posted February 13, 2008 Can I have my gold star and PhotoShop Guru status now please? 8) Wayne what are you saying Wayne? ;D Link to comment Share on other sites More sharing options...
wfarnworth Posted February 13, 2008 Share Posted February 13, 2008 what are you saying Wayne? ;D I feel I've contributed enough on here now to be awarded this much at least :-) Wayne Link to comment Share on other sites More sharing options...
willcolumbine Posted February 13, 2008 Share Posted February 13, 2008 You get about 30 seconds to practice that task but it does comes at the end of a lot of other tests so by the time you come to do it you'll already have done the number, shape and joystick task individually. There was also a crazy test where it'd say something like 'positive left hand square' and then show you three guys holding different shapes (and maybe facing you or away from you or upside down etc). You have to press the number of guys that are holding that shape or not if it specifies negative. You have 5 seconds to decide at the beginning but they gradually reduce it to 2! Link to comment Share on other sites More sharing options...
wfarnworth Posted February 13, 2008 Share Posted February 13, 2008 In fact I think you should create a new category - along the lines of Technical Donkey Pop that under my Frank! ;-) Wayne Link to comment Share on other sites More sharing options...
DaveNotSoSideways Posted February 13, 2008 Author Share Posted February 13, 2008 Will. You must sleep well after a day of these days! I guess you sharpen up pretty quick! Wayne? ;D ;D You were saying? Link to comment Share on other sites More sharing options...
wfarnworth Posted February 13, 2008 Share Posted February 13, 2008 Oh yes!!!! I thank you! ;D Wayne Link to comment Share on other sites More sharing options...
DaveNotSoSideways Posted February 13, 2008 Author Share Posted February 13, 2008 Thou ask, thou might recieve... Can I interest you in some cheap Branston Pickle? Link to comment Share on other sites More sharing options...
sorbs Posted February 13, 2008 Share Posted February 13, 2008 Where have I seen that test before? I'm crap at it! ;D Link to comment Share on other sites More sharing options...
PHOENIX Posted February 13, 2008 Share Posted February 13, 2008 it was here first honest LOL Link to comment Share on other sites More sharing options...
sorbs Posted February 13, 2008 Share Posted February 13, 2008 Yeah yeah! Link to comment Share on other sites More sharing options...
Royboy66 Posted February 14, 2008 Share Posted February 14, 2008 oh fook! I just passed my record of 15seconds! :-/ and knocked the coffee cup everywhere!! oops!! : Link to comment Share on other sites More sharing options...
