gt5r Posted January 19, 2008 Share Posted January 19, 2008 Thought I'd upload some vented discs dimensions as I spent hours trawling the net etc to size a pair for my GT6 - so just found the document I compiled about 8 months ago - its useless info time - been looking to run bigger discs on the front and going to a 16' or 17' rim means the worlds my oyster - the discs below are all vented with a 4 stud fixing to the hub - we all know the 2.8i Capri discs is the common upgrade but I was looking for something bigger - also to move the disc to the outboard side of the hub to dissipate the heat more effectively - hence the increase in 'top hat' dimension - anyway might of interest to some - links are below also - have a read of the Capri sport pages as the throws a different light onto the subject of braking - also worth looking at the VW Corrado discs used on the mgf conversion in the link below - the brake store link has some pictures but more importantly the dimension of all discs - enjoy Ford 2.9 V6 24V Cosworth 1995 - 1998 Vented Mountings 4 Discs diameter 278.0mm Discs thickness 24.0mm Overall height 47.0mm Centre diameter 63.6mm Ford RS 2000 Cosworth 1995 - 2000 MK6 Vented Mountings 4 Discs diameter 260.0mm Discs thickness 24.0mm Overall height 43.8mm Centre diameter 63.6mm Minimum thickness 22.2mm Ford RS turbo 1986 -1990 Vented Mountings 4 Discs diameter 260.0mm Discs thickness 24.0mm Overall height 58.1mm Centre diameter 63.6mm Minimum thickness 22.8m Ford Puma 1.7 - 2000 onwards Vented Mountings 4 Discs diameter 258.0mm Discs thickness 22.0mm Overall height 43.5mm Centre diameter 63.6mm Minimum thickness 20.0mm Peugeot 307 2004 onwards HDI Vented Mountings 4 Discs Diameter 266.0mm Discs thickness 22.0mm Overall height 34.5mm Centre diameter 66.0mm Minimum thickness 20.0mm Ford 2.8i Capri Vented Disc Mountings 4 Studs 4 Disc diameter 245.0mm Disc thickness 20.0mm Overall height 32.0mm Hub hole diameter 68.3mm Peugeot 405 1988 - 1996 MI-16 4x4 Vented Mountings 4 Discs diameter 266.0mm Discs thickness 20.5mm Overall height 27.4mm Centre diameter 66.0mm Minimum thickness 18.5mm http://www.brakepartssuperstore.com http://www.zyworld.com/caprisport/ http://www.mgcars.org.uk/cgi-bin/gen5?runprog=mgoc&a=&p=emg/mgftfbrakes.html Link to comment Share on other sites More sharing options...
triumphlux Posted February 8, 2008 Share Posted February 8, 2008 I ordered a spacer kit for my type 16 calipers and will source the Capri discs myself. But there ar a few disc types mentioned for the Capri. Do you know which is the correct one ? (Capri model or part no) Thanks Link to comment Share on other sites More sharing options...
gt5r Posted February 8, 2008 Author Share Posted February 8, 2008 Hi Triumphlux The discs you need are from the 2.8i Capri only - as far as I'm aware there is only one listining for this model and the part number on the Brakeparts web site is BDS4335 the dims are below - hope this helps Vented Disc 4 Studs Disc diameter 245.0mm Disc thickness 20.0mm Overall height 32.0mm Hub hole diameter 68.3mm Link to comment Share on other sites More sharing options...
DaveNotSoSideways Posted February 8, 2008 Share Posted February 8, 2008 (thumbsup) Link to comment Share on other sites More sharing options...
triumphlux Posted February 13, 2008 Share Posted February 13, 2008 Sorry for answering so late, but I have been at the Stoneleigh Show and only came back yesterday morning .... I live in Luxemburg, so it took some time to drive back. THANKS for the details, so I can order them at the local motor parts supplier Link to comment Share on other sites More sharing options...
gt5r Posted February 13, 2008 Author Share Posted February 13, 2008 Luxemburg - wow You will need to re-drill the Capri disc so it has the Triumph disc PCD - if you have a piller drill you can do it yourself - somewhere I have a template - machined a piece of steel so as it locates in the capri disc - has guide holes @ the triumph pcd- either centre punch or drill through the template - its now surplus to me as I am using Ford dics and hubs on my Triumph - if you pay the shipping you are welcome to it as I no longer have use for it - if I can find it that is !!!! Link to comment Share on other sites More sharing options...
triumphlux Posted February 14, 2008 Share Posted February 14, 2008 I have a small piller drill but my father has a really heavy one so I will do it on that one. The template sounds interseting, if you find it can you check he postage costs for me ? Link to comment Share on other sites More sharing options...
Gerard Posted February 14, 2008 Share Posted February 14, 2008 JC, Building a race car to keep up with the traffic? ;D I thought the braking on your Vitesse was ok, with the servo and everything... Link to comment Share on other sites More sharing options...
triumphlux Posted February 16, 2008 Share Posted February 16, 2008 Gerard you know that the Vitesse will look like a Herald and generally people driving in Luxemburg always think that old cars are slow ...... so powerfull brakes are a good investment .... and it is quite easy to uprate these brakes ...... so I will go for it Link to comment Share on other sites More sharing options...
triumphlux Posted April 15, 2008 Share Posted April 15, 2008 Tried to source the discs today and they needed 25 min to find somebody who could supply them, will see in two days if they are the correct ones. Link to comment Share on other sites More sharing options...
