vovka
    14
About vovka
  1. Butterflies 7481.1 and 7481.2 is interchangeable ? My carbs is DHLA 40E with 4 progression holes. thanks.
  2. My fuel pump: Carter P60504 http://www.federalmogul.com/en/AftermarketSolutions/NorthAmerica/EngineSolutions/Products/CarterFuelDelivery/CarterElectricFuelPumps/CarotorGerotor/ http://www.carterfueldelivery.com/fuelpumps/pdf/support/TEC1620.pdf EXTERNAL MOUNT UNIVERSAL 12V ELECTRIC FOR CARBURETED CARS AND TRUCKS IMPORT & DOMESTIC NOT FOR FUEL INJECTION filter attached to the inlet to protect the pump Negative ground Free Flow Rate: 30 gph Maximum Pressure (psi): 4 psi Inlet Size: 5/16 in. Inlet Quantity: Single Inlet Attachment: Hose barb Outlet Size: 5/16 in. Outlet Quantity: Single Outlet Attachment: Hose barb Very good pump. Low pressure. I'm using his 2 year. No problem.
  3. Hello. Please advice me for correct jetting on Dellorto DHLA 40E (5 progression holes). Engine: 1.4 (79mm bore, 71mm stroke) 306 degree camshaft, 2.5mm LATDC. 4-1 exhaust manifold, 51mm pipe. Carbs jetting: idle 7850.2/52 (little lean, AFR=14.7-13.8 from 1000 to 3000) 32mm chokes .2 venturi .6 emulsion tube 155 air corrector 118 main jet (maybe very lean on the high revs, but currently i'm not rev up the engine more than 3500 rpm. only 150 miles after engine rebuild.) 40 pump jets. Also i have emulsion tube 7772.7, aux. venturi 7848.1, idle jet holder 7850.1, and many jets. Will work correctly .2 venturi with .6 emulsion tube ? maybe .1 venturi will be best ? I want tune carbs for long progression (currently engine is little stumble around 3000 rpm). Please help me. Thank you.
  4. Sorry, but we don't have rolling road closer than 550 km from my city. And operator of rolling road have no experience with dellorto. In my city (1 000 000 peoples) only a few cars (two .. may be three) running on dellorto dhla or weber dcoe. Also in my country unrealistic to buy a spare jets for dellorto. I buy them in Italy (ebay seller alfa1750).
  5. I installed race camshaft on my 1.6 with dhla 40. Timing: 64-96 93-61 Lift@TDC 5.2/4.9 mm My current jetting: chokes 36mm main jets 150 air correctors 155 tube 7772.7 Very lean after 5000 RPM. AFR 13.5-14.5. IMHO main jets is too small.. Help me please.
  6. Thanks! My current settings: chokes 32 main jets 132 air corrector 155 (GAP/space between the idle and main circuits much less than before) idle jets 52 (little lean), but 57 little rich try to buy 55 idle jets. needle valve 175 (RCA) fuel level 27 mm float full droop 27mm. fuel pressure 3.6 psi ( maybe too much) carter P60504 fuel pump without fuel pressure regulator. AFR at WOT, 4 gear (gear ratio 1.31), about 6000-7500rpm (my LM2 not show correctly RPM (censored) ) time afr 20.97152 12.25 21.05344 13.51 21.13536 12.89 21.21728 12.19 21.29920 12.27 21.38112 12.32 21.46304 12.72 21.54496 12.39 21.62688 12.27 21.70880 12.42 21.79072 12.29 21.87264 12.32 21.95456 12.38 22.03648 12.42 22.11840 12.66 22.20032 12.33 22.28224 12.51 22.36416 12.36 22.44608 12.72 22.52800 12.70 22.60992 12.54 22.69184 12.48 22.77376 12.72 22.85568 12.67 22.93760 12.63 23.01952 12.66 23.10144 12.52 23.18336 12.48 23.26528 12.47 23.34720 12.45 23.42912 12.57 23.51104 12.29 23.59296 12.60 23.67488 12.44 23.75680 12.29 23.83872 12.10 23.92064 12.29 24.00256 12.25 24.08448 12.04 24.16640 12.22 24.24832 12.16 24.33024 12.17 24.41216 12.25 24.49408 12.16 24.57600 12.16 24.65792 12.30 24.73984 12.32 24.82176 12.47 24.90368 12.26 24.98560 12.38 25.06752 12.47 25.14944 12.26 25.23136 12.26 25.31328 12.38 25.39520 12.26 25.47712 12.32 25.55904 12.33 I think fuel pressure too much, and maybe needle valve too much.
  7. Hello. What number of pump diahragm should use in DHLA 40E ? http://www.dellorto.co.uk/merchandise/products_details.asp?PartNo=10742&CategoryID=1&PartsectionID=1 Diaphragm with center disc diameter 22.1mm will work fine ?
  8. Hello. I have the twin DHLA 40E on my Lada Samara 1615cc (8v, forged pistons, ported head, big valves, compression ratio 11, 294 cam duration and 4mm extra lift than stock ones, lift @TDC 2.8mm, exhaust manifold 4-1, etc). The current setup is listed below. Chokes 32 Main Jet 132 Emulsion Tube 7772.7 Air Corrector 175 Idle Jet 52 long-nose Idle Jet Holder 7850.1 Pump Jet 33 5 progression holes. Aux. venturi .2 Fuel level 27 mm. I have some troubles Idle speed is ok - 900 (+-40) rpm, but idle mixture screw turn out 6.5 turns! This is normal for DHLA 40E ? Video: Flame color in combustion chamber at idle is correct (bunsen blue). And i have hesitation on 2700-3200 RPM. I need to know the jet settings. Help me please. Thanks.
  9. My idle jets ( from DHLA 40E):
  10. vovka
    DHLA45D info?
    look here: http://photo.2108.lviv.ua/dellorto/emulsion_tube_7772.7_dhla_2.jpg http://photo.2108.lviv.ua/dellorto/emulsion_tube_7772.7_dhla_3.jpg 7772.7 is very similar to 7772.5
  11. http://web.archive.org/web/20020210151736/http://members.aol.com/DVandrews/
  12. 7298.2 = 10gr : Floats from my Dellorto DHLA 40E (5 progression holes)
  13. Hello. I am owner 2108.lviv.ua I found this information when it has long been in one forum (like club.triumph.org.uk) and recorded to my computer. After lot of time, I could not find where I copied it , and posted on my website, as it seemed useful to me, but I wrote that this information found on the Internet and copyright are not my. Now I looked at your website and make sure that you are the author of this information. I posted here http://2108.lviv.ua/archives/dellorto-dhla-40-universal-performance-112.html link to your website http://www.sideways-technologies.co.uk/ I hope for your understanding. Sorry for the bad English, I used google translate.
