lordleonusa
    1,604
  • Days Won
    1
About lordleonusa
    World Champion!
  • Interests
    My Vitesse, improving my Vitesse, photography, cars that interest me, tales of daring-do, travel, sleeping, eating, beer, music that interests me, science-fiction films, motorsport, especially WRC, Le Mans, F1 and drag racing, oh yeah, and my Vitesse!
Contact Methods
  • Yahoo
    lordleonusa@yahoo.com
4,041 profile views
  1. Matt, Don't make any hasty decisions that you may regret in time. Put the car on stands, cover it up, forget about it, it'll still be there for you later, if you get your mojo back. Trust me, this is the way to go. Leon
  2. Its kind of neat, but I am concerned about the positioning of the fuel tank. I don't even like the position of the fuel tanks in my Vitesse and aim one day to have one made to fit above the rear axles. Leon
  3. Yesterday played with my new jet-washer underneath my wife's truck and underneath my Vitesse, that shifted a lot of grot! I am liking this toy! Leon
  4. Finally finished replacing both the fuel and water hoses on the Vitesse today. It took no less than three attempts to get the right hose, first time they sent me 60" of 0.250" ID hose, then they sent me 60" of 0.500" ID hose in absurdly bright blue, then they finally sent me what I wanted, 60" of 0.500" ID silicone hose in BLACK. to SAE J20. All I have to get now is a few stainless steel clamps, without the holes in, that's all the l;ocal flaps have. Next I am going to get a pair of replacement SS throttle cables in a teflon-lined housing in black, instead of the blue that I presently have on there. I have finally found a supplier of those, intended for go-carts. Leon
  5. Nice Lambretta. Today, I completed the fuel system renew on my car. Oh and BTW, I had purchased another Mr.Gasket fuel filter as a spare for my car, and guess what, at some point during the ten years between buying the old identical looking filters, they have changed the threads again! Now, 24 TPI, I played with it for a while, cracked the housing and threw it in the bin, except for the filter element that I can reuse. (yup, made and printed in China, now looking for alternatives)... Anyhow, I went to the fuel station and bought two gallons of 110 Octane Ethanol Free Race Gas for starting the car for the first time this year. It fired up on the key, (good job battery tender, 13.9 volts all winter). [that's two U.S. gallons at $7.99 each] Checked it for leaks, found none, drove to town, stopped for less expensive two gallons of Ethanol Free 92 Octane, (that's equivalent to about 95 UK Octane), for $4.949 each gallon. That's almost the same as 10% Ethanol Fuel Super at the normal fuel station. Checked again for leaks, found none, drove another two miles to my workplace, found no leaks, and drove home, no leaks, but it was really hot here today, about 85 degrees Fahrenheit. Leon
  6. NPT and BSP are two different standards for threaded pipes. NPT stands for National Pipe Tapered and is primarily utilized within the United States. BSP, or British Standard Pipe, can be found in many other countries. The difference between these two thread types can be seen in the number of threads per inch and the angle at which the threads themselves are cut.These sizes and pitches vary depending on the size of the pipe. BSP pipes often includes more threads per inch (TPI) than NPT, but these are not standard rules. A pipe of one inch in diameter, threaded to NPT standards, includes 11.5 TPI, while BSP uses only 11. As the pipe becomes smaller, the TPI increases in both standards from 27 TPI in a pipe of 1/16" NPT pipe, to a TPI of 8 in pipes of 2 1/2" diameter or larger. Though NPT and BSP are common throughout the world, many cities and industries, such as fire fighting, define slightly different thread standards.The two standards are also further divided into whether the pipe threads are tapered or parallel. Parallel threads maintain the same outside diameter throughout, and thus do not form a tighter seal as one goes further down the thread. By contrast, taper threads create an increasingly tight seal as the pipe is screwed in further. Plumbers typically use tapered threads in applications relating to gas, while parallel threads are common with water lines. The British Standard Pipe has two types, BSPT (British Standard Pipe Taper) and BSPP (British Standard Pipe Parallel). These two types have the same angle, pitch and number of threads, but the BSPT will have a tapered thread while BSPP uses a parallel thread. National Pipe threads standards have two types: NPT (National Pipe Taper) and NPP (National Pipe Straight). NPT similarly differs from NPP through the usage of a tapered thread. More reference links: www.relab.cn
  7. but why would Mr.Gasket Co, based in Ohio be using British Standard Pipe on their products, whereas National Pipe Thread is more common here and indeed on Triumph engines from the UK! confused Leon
  8. Good point, but I don't come from where I find myself! Leon, somewhat left of centre, geographically speaking.
  9. Decided that while I am working in the boot, and have the glass/nylon mesh fuel filters off, I will replace the plastic barbs as supplied with the filters with brass barbs. It turned out that the black plastic barbs and the filter body has a thread of 28 tpi, with a 1/8th inch barb. (now that is a stupidly unavailable thread size if ever I saw one!) Needless to say, the brass barb has a more normal NPT 27 tpi, and 1/8th inch barb. After bashing my head against the nearest brick wall for a few minutes, I used a tap to change the thread size in the body of the filter at each end to NPT 27 tpi at each end, so that I could use the brass barbs that I already have. I also replaced the nylon filters and the rubber sealing rings in the filters, while they were out. I have realised that I will have to remove the engine bay filter to do the same thing to the threads. Also today, I replaced the top radiator hose, (made of Kevlar reinforced rubber), with a black silicone replacement from the TSSC. I also replaced the heater valve to engine RH side water pipe, (Kunifer) with a couple of black silicone hoses, presently joined with a 2" steel pipe, soon to be replaced with a nice alloy made-for-purpose pipe from Pegasus Racing. Finally, I will tomorrow be ordering a 45" long black silicone water hose to replace the rubber water hose that is running along the RH side of the engine. That lot should take care of all the water and fuel hoses and joints for the next 15 years, or so...
  10. OK, taking a step back, the above 30R14 I have not yet been able to find anywhere, but what I have in fact managed to get ahold of is 30R9, which is certainly better quality than my present 30R7. Gates - Fuel Injection/MPI Hose Part Number: 27095 Line: GAT 1 Year Limited Warranty UPC: 38244244720 5/16" x 25' (180 PSI) Detailed Description Recommended for clamped hose applications on all fuel systems, including fuel injection systems. Not designed to replace coupled hose assemblies on fuel injected engines. Approved for use with leaded and unleaded gasoline, diesel fuel and gasoline blends of ethanol, methanol and ethers (up to maximum concentrations allowed by the EPA) and 100% methanol or ethanol. 60% fluoroelastomer liner resists permeation and alcohol. Oil resistant tube combats heat. Polyester braid reinforcement increases strength. Oil resistant cover resists heat, ozone and abrasion. Meets SAE 30R9 requirements. Temperature Range: -29 degrees F (-34 degrees C) to 257 degrees F (135 degrees C). Intermittent Maximum Working Temperature: +302 degrees F (+150 degrees C). Note: Intended for use with fuels where MTBE concentrations are no greater than 15% by volume. Brand Information Recommended as the premium choice for clamped hose applications on all fuel systems, including fuel injection systems. Not designed to replace coupled hose assemblies on fuel injected engines. Approved for use with leaded and unleaded gasoline. I hope that is a bit clearer!
  11. My new Gates hose is 5/16th inch diameter, the hose clamps are 14mm.
  12. Due to time constraints etc, work on refitting my oil cooler has been put aside while I replace the 30R7 fuel hose with fuel injection hose in 30R12, which is resistant to modern ethanol based fuels, the car should no longer smell of fuel, as the new hose is lined and not permeable to the fuel. I am also using ABA fuel hose clamps in 304 stainless steel, these are the bees knees, rolled up at the edges to prevent cutting into the hose, and so much nicer than the cheapo clamps sold everywhere. I got them on-line from a BMW specialist on the east coast of the USA. More later.
  13. Well now. let's see, we are relatively safe when a big earthquake runs up the pacific coast fault-line, about 30 miles off the Oregon coast, and the 100 foot tsunami wipes out Seattle, WA, and Portland, OR. Simply because we are 1390 feet above sea level, but then there's the destruction of the main Interstate 5 that the trucks use North-South to supply our food/fuel etc. Not to mention the subduction zone. There is of course the world's biggest super-volcano in Yellowstone only about 560 miles away, and we are within the 600 mile radius of destruction. The only normal Volcanoes that are still active around here are Mounts Rainier, WA, Mount Hood in Northern Oregon and Mount Siskyou about 60 miles south of here. Hmmm, wonder how long the food, water, fuel and sanity would last? There's a lot of folk with guns in Ory-Gun!!! All paid up card carrying members of the NRA and the Republican party! Leon
