Modified And Fabricated Tools - Show & Tell
  • Please log in to reply
12 replies to this topic
#1 JohnD
JohnD
    Loves monkeying with his car
  • Supporter!
  • 2,804 posts
Posted 09 August 2017 - 09:58 PM
Here's two of mine:
Angled spanners.    I have Malcolm Jones's 'overhead' Pi throttle linkage, that has droplinks down to the butterfly spindles, between the throttle bodies.  They need to be adjusted for length, and have small spherical bearing at each end, with opposite threads, so the link bar can be turned to do that.  But the lock nut at the bottom is inaccessible without these 8 and 10mm spanners, whose open ends have been cut off and welded back on at an angle.
Limited access puller.    The radiator is right in front of the engine on a Vitesse, no space to use a convenional tripod puller.   I made this to do the job.   It's a bar with short 'jaws' at each end, bolted on so that the distance from the jaw tip to the bar can be adjusted by spacer washers, for different thicknesses of pulley.    Place it across the pulley and undo the pulley bolt.  As the bolt comes out, the pressure on the bar pulls the pulley off.       A useful trick is to place a small bead of weld exactly where the bolt head centre presses on the bar, which stops it wandering off centre.
What have you got?
#2 JohnD
JohnD
  • Supporter!
  • 2,804 posts
Posted 14 August 2017 - 08:22 AM
I'm surprised!   I posted this "In Another Place", that I associate with a more staid and conventional approach to Triumphs, and it had a dozen posts in no time and is now in four pages.
Surely the ingenious minds of Sideways have secrets to share?
Or else you all go there as well, under another name??
Edited by JohnD, 14 August 2017 - 08:23 AM.
#3 Spit131
Spit131
    Fast Driver!
  • Supporter!
  • 395 posts
Posted 15 August 2017 - 02:54 PM
Don't stop posting here John , people like yourself are much valued even if the response is not visible . M
#4 oldtuckunder
oldtuckunder
    Fast Driver!
  • Members
  • 543 posts
Posted 15 August 2017 - 03:43 PM
What you have to remember is that a lot of members of "Another Place" have a lot of time on their hands  :yes: just try asking if its best to fill a Triumph with oil from the left or right hand side of the car and you'll rapidly get a four page link of suggestions  :P including many that will insist that if Brexit happens it will then be possible to do it via the boot as the stupid EU regulation that says you must open the bonnet first can be scrapped!
#5 oldtuckunder
oldtuckunder
    Fast Driver!
  • Members
  • 543 posts
Posted 15 August 2017 - 03:54 PM
Here's one to ponder
#6 rogerguzzi
rogerguzzi
    Just passed my test!
  • Members
  • 243 posts
Posted 15 August 2017 - 05:04 PM
Capillary thermostat nut at a guess or oil thermostat same type?
Ps A bit big for our brakes
#7 oldtuckunder
oldtuckunder
    Fast Driver!
  • Members
  • 543 posts
Posted 15 August 2017 - 06:01 PM
Right lines, Lambda Sensor spanner, slips over wires, lots of leverage, small rotation increments.
#8 rogerguzzi
rogerguzzi
  • Members
  • 243 posts
Posted 15 August 2017 - 06:28 PM
Hello Alan
                 The 7/8" confused me I though Lambda was metric size or is 7/8" close enough?
I have a draw full of special tools for motorcycles and cars (not sure what some are for now?)
I will lay them out and take a photo or 2 or 3?
#9 oldtuckunder
oldtuckunder
    Fast Driver!
  • Members
  • 543 posts
Posted 15 August 2017 - 06:56 PM
Ah 7/8 Whitworth. Almost redundant when I was a lad, but have a number of them from my father, amazingly useful at times to have something not quite the right size!
#10 JohnD
JohnD
  • Supporter!
  • 2,804 posts
Posted 15 August 2017 - 07:41 PM
No probs, Spit131, just saying!
Alan, if you have been to t'Other Place, you'll have seen some splendid ideas..  I'm just touting for more - as if I have a book contract to fulfull!
And Whitworth.    I have a 1/2" Whitworth spanner, that used to sit in the bottom-most drawer (NEVER throw away a tool) until I realised - it fits the crank pulley bolt, and is the right length to turn the engine for valve setting.   All my others that big are too long - men were men, with strong wrists in those days.
And since we're discussing spanners, here's a modified one.    The front 9/16 AF nut under the exhaust manifold is so close to the engine mount that any ordinary spanner can only make a quarter turn, and even a multipoint ring has to be turned over every stroke.    This one is cut down to 120mm and drilled, so that I can wire a length of 1/4" tubing over it, tighten the nut twice as quickly and exert the necessary 20lbs-ft of tourque with my manly Whitworth wrist, without crippling my Southern wuss jessie fingers.  Once it's nearly there, a length of steel rod slips inside the tube to press the final fractional turn.
#11 JohnD
JohnD
  • Supporter!
  • 2,804 posts
Alan, if you have ben to t'Other Place, you'll have seen some splendid ideas..  I'm just touting for more - I have a book contract to fulfull!
And Whitworth.    I have a 1/2" Whitworth spanner, that used to sit in the bottom most draer (NEVER throw away a tool) until I realised - it fits the crank pulley bolt, and is the right length to turn the engine for valve setting.   All my others that big are too long - men were men, with strong wrists in those days.
And since we're discussing spanners, eher's a modified one.    The 9/16 AF nut under the front exhaust manifold is so close to the engine mount that any oardinary spanner can only make a quarter turn, and even a multipomnt ring has to be turned over every stroke.    This one is cut down and drilled, so that I can wire a length of 1/4" tubing over it, tighten the nut twice as quickly and exrt the necessary 20lbs-ft of tourque with my manly Whitworth wrist, without crippling my Southern wuss jessie fingers.
#12 rogerguzzi
rogerguzzi
  • Members
  • 243 posts
Posted Yesterday, 10:28 AM
Hello John
                 Does this count? cobbled together a power drive for my small milling machine(Heath Robinson would be proud of it?)
I am using the switch off the old drill for testing but have ordered one of these now it appears to work
http://www.ebay.co.u...353.m2749.l2649
#13 JohnD
JohnD
  • Supporter!
  • 2,804 posts
Posted Yesterday, 12:26 PM
Heath Robinson would be jealous!
I bought one of these NVR (No Voltage Release) switches for my pillar drill.    Couldn't get one the same as fitted, that had failed, so I was bit chuffed to be able to fit this by reshaping the bracket on the drill and making up adaptor connections, tah involved filing down some spade connectors!  Can't show a pic as its all reassembled neatly and invisibly now!   I presume yours has a speed control?
But this thread is really about hand tools, not "how I cobbled together a synchrotron, from a few TV magnets"
KISS!!
Edited by JohnD, Yesterday, 12:34 PM.
