Cv Conversion Volvo Lobro Lateral Clearance
  • Please log in to reply
5 replies to this topic
#1 Martin
Martin
    Fast Driver!
  • Supporter!
  • 362 posts
Posted 23 July 2017 - 04:12 PM
didn´t want to use the Guide to cv thread.
The Volvo 340 lobro has appr 0,75mm lateral clearance on the Rover driveshaft.
Do I need to shim that somehow?
Martin
did want to contact you directly Nick  but my private and business mail has problems
#2 Nick Jones
Nick Jones
    Wise beyond his years.
  • Administrators
  • 6,729 posts
Posted 23 July 2017 - 06:37 PM
Hi Martin,
Yes, I shim it and also use spline locking compound on final assembly.  I have some shims here but the thickness is not ideal as usually 1 is not enough and 2 is too much......  Happy to send you some if you want?
#3 Martin
Martin
    Fast Driver!
  • Supporter!
  • 362 posts
Posted 24 July 2017 - 06:56 AM
Hi Nick,
are these shims special ones for driveshafts (with a spline pattern?) or "normal" round ones?
For nomal ones  I always "visit" the storage of a mate with a machine shop.
Martin
#4 Nick Jones
Nick Jones
  • Administrators
  • 6,729 posts
Posted 24 July 2017 - 12:06 PM
Just normal round ones.
#5 Martin
Martin
    Fast Driver!
  • Supporter!
  • 362 posts
Posted 24 July 2017 - 06:03 PM
shims sourced with a short visit at the mate´s workshop.
However, the snap ring seems to be weakened. I measure 1,6mm Diameter with an outer Diameter of 24,5mm. The grove is 2mm wide.
Can you confirm this data?
Martin
#6 Nick Jones
Nick Jones
  • Administrators
  • 6,729 posts
Posted 24 July 2017 - 06:51 PM
Not critical provided it all fits together snugly.  I usually re-use the ones from the Rover shaft which have "ears" for circlip pliers.  Clips are usually narrower that the groove - 1.6 - 1.8mm maybe, which needs to be considered when choosing the shims.  Don't have any on hand to measure.
