Soot Monster
  • Please log in to reply
9 replies to this topic
#1 Nick Jones
Nick Jones
    Wise beyond his years.
  • Administrators
  • 6,633 posts
Posted 07 February 2015 - 08:40 PM
As some of you may know, my daily driver for the last 11 years has been a 1996 Audi A6 Avant 2.5TDI.  This has an I5 turbo diesel giving 140bhp and a 6 speed manual box.  Cutting edge for 1996.
It was the leased company car of my boss when I joined my current employer in 1997, was bought  from the leasing company by another colleague and I bought it from him in 2003 with 112k on it.  Nearly run in.  The boss is on his 5th car since.
It has been a GOOD car.  Now just a few hundred miles short of 275k, it has had few replacement parts that would not be considered consumable.  Exhaust, clutch, alternator and starter are original as are all the brake calipers and the rear wheel bearings.  The engine has had no attention bar cam belt changes (2 in my ownership) and still uses virtually no oil.  It has lived outside all it's life and yet apart from front wings (the arches are a known rot spot where the liners rub through the galvanising) the body and paint are original and it still looks ok when I wash it, though it does have a pretty extensive stone chip collection.  It's my work car and earns 45p a mile (typically 8 - 10k a year) so it's been a good earner.
It averages nearly 50 mpg.
It gets used for whatever job is going which has included dragging car trailers with large cars on (I'm not saying what!), trailers full of rocks and being stuffed with whatever will (almost) fit in it or can be tied onto it.
It has survived 6.5 seasons of the Woolbridge MC 12 car rally series, which although not really a speed event does involve some really bumpy lanes usually in atrocious weather.  I have discovered that it can wade through water up to 2' deep (enough to make the back float), but I suspect I was very lucky to get away with that!
Is this an obituary?  Not yet.  It is now showing signs of attrition though.  I have become used to thinking it was invincible, but it has a growing list of maintenance tasks.  Certain of my long-standing customers greet me with "hasn't that b***** thing died yet?"
Apparently the injector nozzles aren't meant to last 275k.  It is now smokier than ever (not called the Soot Monster for nothing!) and is a bit of bugger to start when cold.  Some of the 140 horses may have escaped.  I'm told that with the right nozzles I can have them all back and more.  Apparently these engines will go to > 240bhp with no internal mods.
Handling has been becoming increasingly "interesting" so I'm mid way through changing the front subframe bushes (shagged), the TCAs (again) and ARB bushes (actually look ok).  The rear axle pivot bushes are absolutely bolloxed (I discovered yesterday) and are probably one of the main reasons for the odd handling.  Changing those involves dropping the whole axle beam out, so I'm really not looking forward to that.
Yesterday one of the fuel tank retaining straps broke on my way to work.  It had rusted through, leading to odd scraping sounds.  Fortunately the tank stayed in place.  Audi wanted £54 for a new one (10 day wait).  I bought a strip of galvanised steel from a local fabricator for £1 and borrowed the ramp and welder of the garage behind work (£20 in pasty fund), so that is now fixed.
So what next?  I've mentioned before that I have an urge for D2 A8.  This hasn't gone away and I actually drove one recently, a full fat 4.2 V8 one.  Oh yes..... that is one fast magic carpet.  With that much grunt, who cares if they are all auto.......  The Soot Monster would be kept on though.  I intend to see it through 300k!
It's spending tonight in the garage as the front subframe is still on the floor........
#2 motov8id
motov8id
    Fast Driver!
  • Supporter!
  • 546 posts
Posted 08 February 2015 - 05:58 AM
My Nephew cam by this weekend and asked for help with his rough running  A6 quattro 3.0. I was a bit out of my league but a set of Bosch plugs and  2 coil on plugs latter all was well and on to something I understood a front axle replacement. So a satisfying weekend. If I could only get my Lambretta LD running
#3 pomwah
pomwah
    World Champion!
  • Supporter!
  • 1,168 posts
Posted 08 February 2015 - 07:23 AM
Only 300k Nick, nah, take it to 500k and then sell it to a minicabber!
#4 Nick Jones
Nick Jones
  • Administrators
  • 6,633 posts
Posted 08 February 2015 - 10:31 AM
This is miles not Kms.  It's already on 440k Kms.....
#5 pomwah
pomwah
    World Champion!
  • Supporter!
  • 1,168 posts
Posted 09 February 2015 - 01:40 AM
500k miles, mmmm? Ah, ahah! To the Moon and back!
#6 Nick Jones
Nick Jones
  • Administrators
  • 6,633 posts
Posted 22 September 2016 - 09:59 PM
The old girl is still dragging herself around.  294k and some change.  Passed an MoT today with the only comment being advisories on the rear wheel bearings which have a little play.  They are the factory originals!  Should make 300k then.
I did change the injector nozzles for new standard ones last summer, which improved the starting and smoke situation but didn't make much different to the fuel consumption or general running - which were ok anyway to be fair.
Also had to sort out the rear brake calipers when one of them stuck on. They were pretty much done for but luckily I was able to find a much lower mileage pair from a local scrapyard and rebuild those with new seal kits.  I've also just renewed all 4 brake discs and pads so it stops well at least.  Could do with (another) set of dampers though. 'Tis the lanes that kill them - bloody bumpy!
One irritating casualty of it's old age is the AC, which no longer holds gas long enough to be useful.  A large black estate car without sunroof needs AC, even in the UK.  Experiences with the A8 show that getting this properly sorted without spending big bucks is likely to be a challenge!
Much as I'd like to find another, lower mileage and well-cared for example, this is pretty unlikely.  It appears mine is one of the better, lower mileage examples left in 2.5 TDI form!  I was mildly tempted by a 2.8 quattro version, but that would give the A8 a good challenge in the drinking stakes and I need one car without a drink problem.....
#7 Martin
Martin
    Fast Driver!
  • Supporter!
  • 355 posts
Posted 23 September 2016 - 10:38 AM
Best cars ever produced were between 1985 and 2000 according to a friend dealing with used  cars the last 40 years.
Since some years I´m driving Volvo V70. The current one is from 2004 with the D5 163hp engine and 5 Speed gearbox.
230.000 km, nice interior with super comfy seats and a real loading area.
Hope that the car does more than 400.000  km like thel old one.
Martin
#8 Nick Jones
Nick Jones
  • Administrators
  • 6,633 posts
Posted 23 September 2016 - 12:09 PM
Yes, I agree with your friend.  You maybe lucky with your Volvo, though the D5 engine does have a few issues.  The older V70 TDI uses the same VAG I5 engine as my A6 and 400,000+ kms is no problem for them.  There is some crazy Swede who drunkenly bet his T5 and D5 owning mates that he could make his TDI faster than theirs.  He got something like 240 bhp (and massive torque) from the standard, untouched, high mileage engine just by changing the turbo, intercooler, injector nozzles and a remap.  He had some problems with the clutch slipping (no, really?!) and when he sorted that he had some problems with the tyres slipping.  There is a video of him giving it full throttle in 5th at 120kph and lighting up both front tyres.  Apparently he was told that it would blow the crank out of the bottom of the engine unless he uprated the main bearing bolts, but so far it lives!
With Audi, this first series A6 and the 80/90 are the last of truly durable ones, designed I think by a very experienced team.  The A8 design team, though smart for sure seem to have less real world car experience and some of the design features they introduced (later carried on to the smaller cars) are just daft.  That crazy multi-link front suspension...... the climate control systems........ the woefully shite rainwater drainage systems in the A8 that more or less guarantee everyone gets water in it at some point.  As for the really new stuff - electric handbrake...... WHY?!
#9 Nick Jones
Nick Jones
  • Administrators
  • 6,633 posts
Posted 06 June 2017 - 09:24 PM
I've not written about this old beast in a while, but it's still soldiering on.  Mileage increase has slowed as I've been using the A8 for some of the longer distance work stuff.
Very close to 300k now.  Bought it a set of new tyres last week - 4 x Toyo CF2s, probably doubled the value!  It had a narrow escape last night as I got rear-ended on the A303 in the pissing rain on the way home from work, but fortunately it was only a glancing blow as the car that hit us had itself been rear ended rather harder and was sliding sideways at the time, plus I was still rolling and off the brakes.  So damage is limited to some paint scuffed off the rear bumper and a cracked light lens.  Could have been alot worse!
It's got a fair collection of annoying clonks, which I concluded tonight are mostly the result of the  original (yes!) exhaust rubbers having sagged considerably over the years so the exhaust system is nearly on it's bump stops.  This is not helped by the "jam" having been squeezed out of the fluid filled engine mounts so the engine sits a few mm lower than it should.  New ones are still available but cost over £ 600 a pair...... :o...... Too rich for me. There may be a non-fluid filled alternative, which needs investigating.
The handbrake linkage / calipers have got a little sticky too - work fine if I use it every day, but stick if left for more than a couple of days.  More investment required.....
#10 Nick Jones
Nick Jones
  • Administrators
  • 6,633 posts
Posted 07 June 2017 - 07:16 PM
and this morning, this happened......
northbound on M5 north of Gloucester.....  I've added nearly 300 miles to that total since.  Too many miles for me today!  Car happy enough though, 53.3mpg average.
Also very much liking the new Toyos which are grippy and quiet compared to the BF Goodrich things that came off.
