Welcome to Sideways Technologies
| Welcome to Sideways Technologies new website. We've moved the old forum onto a new server and new software. If you were previously registered, your old userid and password should still work. If it doesn't please send an email to forum "at" sideways-technologies.co.uk If you're here as a guest, your free to read and browse the forums, but we do encourage you to register. You must register if you wish to post, but don't worry this is a simple free process that requires minimal information. By registering and signing in, you can enjoy all the benefit our members do.
Guest Message by DevFuse
Knackered Drums?
Started By SteveA, Feb 02 2012 09:15 PM
11 replies to this topic
#1
Posted 02 February 2012 - 09:15 PM
I've been setting up the rear drum brakes and handbrake on my GT6 tonight, but as I adjusted the shoes I noticed on one side they would bind slightly during one part of the rotation. I pulled the handbrake on and off a few time to try and centralise the shoes, but it didn't improve the situation.
Is this occasional binding a sign of knackerd brake drums?
#2
Posted 02 February 2012 - 09:42 PM
They are probably not quite round. Most of them seem to be not quite round....... some worse than others. Deglazing the inside surface sometimes helps.
You have the drum centring rings on your CV conversion?
#3
Posted 02 February 2012 - 09:45 PM
Yes I have the centralising rings, I'll have a go at deglazing to see if that improves it.
#4
Posted 03 February 2012 - 08:21 AM
Hi Steve,
Take them to your local machine shop and ask them to check them and if they are out machine them round again. Will not cost much.
Chris.
Chris.
#5
Posted 03 February 2012 - 10:46 AM
Not really much point at £20 a drum, just replace them if all other options are checked.
You taken the drum off made sure nothing if fouling the shoe? get someone to push the pedal whilst you look at the slave cylinder aswell i had a sticky one once.
#6
Posted 03 February 2012 - 01:06 PM
Not sure if they are available right now. Certainly they were not for a while. No reason why new ones should be round either with current production standards......
Both of mine do what you describe Steve, and work ok in practice. I did have one that was quite severe and swapped it for a better one.
#7
Posted 03 February 2012 - 02:32 PM
Really wow, didn't realise here was such a shortage, think i still have a set of gt6 ones in the shed, must ebay.
#8
Posted 03 February 2012 - 02:44 PM
There seem to be 2 variants
Mk3 up to chassis # KE/KF 20,000 uses 203077
Mk3 from chassis # KE/KF 20,000 uses 215754
Don't know for sure but It looks like they are back in stock.
http://www.angserv.d...co.uk/rdrum.htm
http://www.canleycla...rt/?ptno=203077
http://www.rimmerbro.../Item--i-203077
#9
Posted 03 February 2012 - 06:28 PM
You'd think that.
I bought a set for my spit. Painted them to look nice. fitted them, less than 200 miles later they would grab and almost lock at one point on each drum, nearly shook the car to bits sometimes.
Sent them back.
Took the originals and got them skimmed round by a friend at work. Fantastic result! Should have done that first.
Mark
#10
Posted 04 February 2012 - 06:50 PM
I bought some new discs for the 2000 which had significant run out and I'm sure were the cause of a nasty judder.
Should have had the old ones machined and saved £100...........
#11
Posted 06 February 2012 - 09:40 AM
I've had another look at the drums and they are a bit scored also, so I guess it could be worth getting them skimmed. Had anyone had drums skimmed recently? I was wondering roughly how much it would cost.
View Garage
