Welcome to Sideways Technologies
| Welcome to Sideways Technologies new website. We've moved the old forum onto a new server and new software. If you were previously registered, your old userid and password should still work. If it doesn't please send an email to forum "at" sideways-technologies.co.uk If you're here as a guest, your free to read and browse the forums, but we do encourage you to register. You must register if you wish to post, but don't worry this is a simple free process that requires minimal information. By registering and signing in, you can enjoy all the benefit our members do.
Guest Message by DevFuse
Mystery Cam
Started By Lincspeed, Jan 18 2012 02:49 PM
48 replies to this topic
#41
Posted 05 February 2012 - 07:01 PM
A TR5 is a 150 cam
#43
Posted 05 February 2012 - 07:30 PM
Can some one say do I need to get a twin choke cable please
#44
Posted 05 February 2012 - 07:55 PM
Theory says you need one - practice says that once you have started it on "choke" - really metering unit enrichment - and blipped it for 30 secs (to get it on all six cylinders
Idle is generally a bit rich on PI's which must help and if you set the airbleed to give a ~900rpm idle it will get just enough air when cold - if you the kind of person who wants it to idle like a modern car from cold - forget Lucas PI
#45
Posted 05 February 2012 - 08:09 PM
Thanks Andy no I want my Pi GT6 to be raw and as far from a modern car as I can
one more question please Andy is it a must to use the Pi air box or can carb trumpets be used instead.
Hugh
Hugh
#46
Posted 05 February 2012 - 09:02 PM
Airbox makes filtering air and supplying it cold a lot easier - individual trumpets with foam filters sounds bonkers but what you gain from the trumpet (45 DCOE btw) you probably lose by putting a foam sock on. There is considerable debate about the airflow ability of the original air trunk but its good for at least 170bhp - I would use the original (it has ram pipes) if you have it and then run a large flexible pipe to a decent remote filter
#47
Posted 05 February 2012 - 09:41 PM
Thanks Andy yes I have the original air box so I will use it thanks
I started to respray the car while the engine is out I have stopped due to my hand op and the cold weather it's going to be painted in satin finish gun metal grey So I only have the engine bay done.
#48
Posted 05 February 2012 - 10:30 PM
Just a thought on the cold idle front. Absolutely no reason why you can't use one of those thermoelectric valves from the K-jet system. Just provides a metered bypass of the throttle(s). Works from engine heat (to prevent high idle at warm/hot start) and has a heater element in it to make sure it doesn't hang on too long from cold. Just needs a 12v ignition switched supply. Early K-jet Volvo 240 works well - has a short duration. Use these on both my EFIs - no ECU involvement.
I'd also use the original airbox with remote filter as Andy suggests - it's a decently engineered thing and that way you'll get cool air into the engine.
#49
Posted 06 February 2012 - 12:20 AM
Thanks for the info for the K-jet Nick it's something I will fit to my car and I use the original air box too
Hugh
