Any window experts out there?
The drivers side window on my brother's E46 323i will go down but not up.
The motor will only turn in one direction (i.e. to open the window) whether the switch is in 'up' or 'down' mode.
We tried a rear window and as you'd expect, that motor changes direction to open /close the window. Connect the rear window motor to the supply for the front window and it'll only turn in one direction.
Fit the front motor to the rear window's power supply and it turns in both directions.
I guess it points to a faulty driver's window switch?
Welcome to Sideways Technologies
| Welcome to Sideways Technologies new website. We've moved the old forum onto a new server and new software. If you were previously registered, your old userid and password should still work. If it doesn't please send an email to forum "at" sideways-technologies.co.uk If you're here as a guest, your free to read and browse the forums, but we do encourage you to register. You must register if you wish to post, but don't worry this is a simple free process that requires minimal information. By registering and signing in, you can enjoy all the benefit our members do.
Guest Message by DevFuse
Bmw Electric Windows
Started By sorbs, Aug 21 2011 03:13 PM
4 replies to this topic
#1
Posted 21 August 2011 - 03:13 PM
#2
Posted 27 August 2011 - 08:16 PM
yep , could be a broken wire or need a clean out with some switch cleaner, here at maplins
D
D
Edited by logicaluk, 27 August 2011 - 08:22 PM.
#3
Posted 28 August 2011 - 09:04 PM
Thanks, next step is to try another switch and see if the window works properly.
There are only two wires to the motor in the door. I expected three, but I guess the switch reverses the polarity of the two wires to change the direction of the motor rather than there being a +ve for each direction of the motor. Shame I didn't have my multimeter with me. Still worth double checking for broken wires in the door hinge area though.
Unless there is an ECU / control unit somewhere which fires electricity to the right place when triggered by the switch.........
#4
Posted 03 September 2011 - 09:35 PM
New switch, problem solved!
#5
Posted 29 October 2011 - 09:15 PM
My brother complains that his 323i auto seems a little gutless but today we took a 0-60 time of 8.9 seconds.
No racing start, uphill, 2 bikes on the roof rack, and of course, 190,000 miles on the clock. Probably not too much wrong with it...........
In fairness, it does seem a bit lacking in low down torque but goes well when revved, I suspect the VANOS variable cam timing thing may be past its best.
Edited by sorbs, 29 October 2011 - 09:16 PM.
