Vitesse project
  • Please log in to reply
388 replies to this topic
#1 triumphlux
triumphlux
    Hot Shoe!
  • Supporter!
  • 846 posts
Posted 02 April 2008 - 08:44 PM
As promised a few pictures of my latest project.
Vitesse Mk2 rotoflex chassis and very good Herald 12/50 bodytub :
#2 Mark
Mark
    Fast Driver!
  • Supporter!
  • 332 posts
Posted 02 April 2008 - 09:17 PM
Looks like a really nice tub judging by the boot floor. Probably being a saloon has helped. A bit more water tight than a convertible. I am in the process of building a MK2 convertible myself and am after a spare wheel well if anybody heres of one.
http://triumphmodsan...n.blogspot.com/
#3 mk2vitesses
mk2vitesses
    Fast Driver!
  • Members
  • 413 posts
Posted 03 April 2008 - 06:11 AM
Without wanting to sound like some anorak judge at a classic car meet, the bulkhead for a Mk2 should have the wide spaced wiper posts.
The LHS post should be on the outside of the screen washer jet!
Just for info 8)
#4 triumphlux
triumphlux
    Hot Shoe!
  • Supporter!
  • 846 posts
Posted 03 April 2008 - 06:18 AM
I didn't know that they changed the wiper position on the Vitesse .... I always assumed that nothing was changed on the bodytub.
Then I need the wiper mechanism from a Herald to fit to that front end ?
Originality doesn't concern me because in the end it will look like a Herald 12/50, but it will hopefully have powerfull Vitesse mechanics  ;D
#5 mk2vitesses
mk2vitesses
    Fast Driver!
  • Members
  • 413 posts
Posted 03 April 2008 - 06:43 AM
Yes the tube length is different between the wiper posts, the Mk1 Vitesse and early Herald are the same as far as I know. The 13/60 bulkhead is the same as the Mk2's.
The cold air grill is also different.
Simon
#6 mk2vitesses
mk2vitesses
    Fast Driver!
  • Members
  • 413 posts
Posted 03 April 2008 - 06:44 AM
Oh I meant to say your rear tube looks good, much better than mine started off!!!
#7 Gerard
Gerard
    Temporary uncivil Servant
  • Members
  • 1,745 posts
Posted 03 April 2008 - 07:02 AM
Wow, that's moved on a bit since I last saw you!
#8 Buster
Buster
    Advanced Member
  • Members
  • PipPipPip
  • 57 posts
Posted 03 April 2008 - 08:30 AM
Only on late ones, design changed in 1969. Same change on late Heralds.
#9 mk2vitesses
mk2vitesses
    Fast Driver!
  • Members
  • 413 posts
Posted 03 April 2008 - 08:38 AM
The only Mk2's I've seen with the close spaced wipers have had the bulkhead replaced with the earlier type. The only bloke I know who would no for cert is Bill.
#10 Smallfry
Smallfry
    Advanced Member
  • Members
  • PipPipPip
  • 93 posts
Posted 04 April 2008 - 11:41 PM
Only the very last mark 2 Vitesses AND 13/60s had this wiper arrangement. It occured mid to late 1970.
#11 lordleonusa
lordleonusa
    World Champion!
  • Members
  • 1,582 posts
Posted 05 April 2008 - 03:16 AM
I believe that the change occured from August 1969.
My Herald and Vitesse both have the original arrangement, but I never noticed any problem with washer jets or wipers...
My Herald 1200 Cv was built in early 1967, and the bulkhead on my Vitesse originated on a 1969 Herald 13/60 Cv.
Regards
Léon
#12 triumphlux
triumphlux
    Hot Shoe!
  • Supporter!
  • 846 posts
Posted 14 April 2008 - 08:56 PM
Some photos of the work I have done the last two weeks :
- fitting grease nipples to the roto wishbone
- sandblasting
- rebuilding front suspension
#13 Oracle
Oracle
    Fast Driver!
  • Members
  • 442 posts
Posted 14 April 2008 - 09:13 PM
Interesting colour that...Quite like it :)
#14 triumphlux
triumphlux
    Hot Shoe!
  • Supporter!
  • 846 posts
Posted 14 April 2008 - 09:20 PM
Primer ... will be painted black  :)
#15 lordleonusa
lordleonusa
    World Champion!
  • Members
  • 1,582 posts
Posted 15 April 2008 - 03:24 AM
Grease nipples on the wishbones, intriguing idea, did it in October 1990, no photo of stainless steel nipples but found this photo showing bearing races instead of standard nylon bushes.
still going strong, 17½ years later!
a Steve Phillips mod'
L
#16 triumphlux
triumphlux
    Hot Shoe!
  • Supporter!
  • 846 posts
Posted 15 April 2008 - 05:42 AM
Leon, do you know which bearings you used ?
and I suppose that these alloy plates on your pic seals the bearings inside the wishbone !?
#17 lordleonusa
lordleonusa
    World Champion!
  • Members
  • 1,582 posts
Posted 15 April 2008 - 07:29 AM
I do not seem to have a record of the ball bearing races used, which is strange, as I thought I did, but I can ask my supplier, who may still hav ethat information as mine was not the only set made.
The end caps are stainless steel, not alloy.
and yes they do.
Here's my only other photo, taken in falling light, which is why it's a little fuzzy, like my memory.
L
#18 GT
GT
    GT
  • GT
  • 3,009 posts
Posted 15 April 2008 - 07:41 AM
Yes it was me that did that modification in fact.
It entails boring out (line boring) the wishbone bushes and fitting klnj 1 1/8" bearing I think was the size.
SO,- I/D bore is the bolt size, O/D the new wishbone bore size and the spacers have to be JUST the right length, so there's no free play, but no friction either.
(so it's the length of the orginal spacer minus the bearing width divided by 2 to get the right length half spacers)
To be honest it was better using 2 bearings and single spacer between them, because if a little moisture gets in there, the bearings don't last long.
It looks to me like SP used a non STD bolt and spacer.
I didn't want to do that for compatibility reasons and the original bolt is cadmium plated (or should be)
The whole lot I packed with grease and sealed with O rings.
It was a very nice mod, but even better if you rose joint the radius arms one end too.
#19 triumphlux
triumphlux
    Hot Shoe!
  • Supporter!
  • 846 posts
Posted 15 April 2008 - 11:52 AM
Thanks for the detailed info and pics
I will measure the wishbone and spacers, then check which bearings I find and modify to suit the bearings.
#20 GT6Steve
GT6Steve
    That Vegas bloke!
  • Supporter!
  • 3,971 posts
Posted 15 April 2008 - 12:15 PM
My memory is a bit fuzzy as well but I have a note in my original GT book correcting that bearing number to KLNJ 1 1/2 or R8.  I explored it at one time but went a different route entirely.
HTH, Steve
