daveygravey Posted May 6, 2009 Share Posted May 6, 2009 Hi, First post! Does anyone know if you can get a quick release boss for the steering wheel on a GT6? I've like to be able to detatch the steering wheel as a security measure. Thanks, Dave Link to comment Share on other sites More sharing options...
mattius Posted May 6, 2009 Share Posted May 6, 2009 only option is welding one to the steering column and as such the welding better be bloody good. Link to comment Share on other sites More sharing options...
Harry Posted May 6, 2009 Share Posted May 6, 2009 An ugly one: http://www.dcp-shop.co.uk/buy-car-accessories/product_info.php?manufacturers_id=38&products_id=12099 or this one: http://www.merlinmotorsport.co.uk/p11003/LIFELINE-GRUPPE-N-SCHNELLSPANNER-CHEF/product_info.html?language=en&osCsid=311dc31d2aef62058082511a634bdc08 or this one: http://www.motorspeed.com/store_main.asp?int_catalog_id=4&int_category_id=16&int_subcategory_id=91&int_product_id=2001 cheers Harry Link to comment Share on other sites More sharing options...
GT6Steve Posted May 7, 2009 Share Posted May 7, 2009 It's hard to tell much from the links but it's safe to say that any of them will add some slop to you're steering on a street car. There are many quick releases on offer, All of them will give you the same issue unless you deal with it up front. Indexing the wheel. You're used to the top of the wheel being straight ahead but you can't assure that after the conversion. A lot of the better QD's have fine splines to impove the feel but exacerbate the problem accordingly. Where's the supplier to offer a fine spline assymetric mount?? Mine is a simople hex adapter welded to the steering shaft, a lightly stressed joint, and I've added a keyway and post to ensure correct lineup each time it's installed. HTH, Steve Link to comment Share on other sites More sharing options...
PHOENIX Posted May 7, 2009 Share Posted May 7, 2009 its one bolt, I have on quite a few ocashins just unbolted it. But I dont use a centre horn button thogh Link to comment Share on other sites More sharing options...
daveygravey Posted May 8, 2009 Author Share Posted May 8, 2009 Cheers chaps - I will consider the options. Link to comment Share on other sites More sharing options...
AllanE Posted September 7, 2011 Share Posted September 7, 2011 (Thread resurrection warning...) I have SPA quick releases on two of my (road) cars - no slop whatsoever and welding them on isn't absolutely necessary - on of mine is just pinned (lightweight AX) the other is Loctite bearing fit-ted and pinned, as it's too close to the top bearing to weld. Link to comment Share on other sites More sharing options...
